insurgence
Hi everyone.. i need a little help with the rented EX1 i have in my hands.
I need to run an external LCD monitor on the cam, so i can flip the images created by my SGPro 35mm converter!
On my regular PD150, there is a standard video out (yellow cable) which produces a feed for my monitor.
On the EX1 there are several small connectors, and the SDI out.
Which one do i use to monitor the video only for my cam-top LCD?
The kit came with a cable for the 'AV out' slot, but does not seem to produce a signal my monitor can 'see'.
will SDI with an appropriate connector (and adpator) do the trick, if so is the cable just a standard yellow video cable (aka the PD150)?
Any help would be really great, as 2moro morning i have a shoot, which will all have to be filmed with the footage viewed upside down... which will be very tricky.
thanks in advance!
thanks in advance!
