insurgence
could any current user of the EX1 tell me....
Does it use the same NP-F infolithium L batteries as old cams like the PD150
thanks
thanks
The EX1 uses BPU models, they are bigger.
There are 2 models:
BPU-60 lasts for aproximately 4.5 Hours
BPU-30 lasts for aproximately 2 Hours (which comes with the EX1)
Do not hold your breathNo unfortunately not. It uses a new type of battery that so far hasn't been cloned by battery manufacturers, so you have to pay full whack for it at the moment.
Do not hold your breathmy sources tell me that reverse engineering the Sony Infolithium code is so painfull that they just are not putting their resources into doing it. The potential demand for the BP-UXX would be much less than the L series, so it is not worth it to them. Without getting the code working your camera would not power up.
BP-U60 doesn't last 4.5 hours on my ex1. I go through two of them plus a BP-U30 when shoot a wedding event.
Might last that long if you use the viewfinder but certainly not with the LCD.
We are getting a Swit S-8U62 battery in for testing, assuming it works out well, will start offering it for under $200.
Trouble is it has to be plugged into the DC socket to work. A bit of a pain in the butt for the saving incured.
