As the DP4-EVF users have found out, the supplied HDMI cable is both too short and has a mini-HDMI connector on one end which makes it near useless with an F3, unless you put a nanoFlash between the camera and the EVF.
Question. What kind of HDMI cables can you use? There are several standards. One is the 1.2a spec, another is the 1.3a and the similar 1.3b spec and the other is the more current 1.4 spec that allows for an ethernet signal to travel through the cable. Is there anyone which is a no go with the F3 and the DP4?
Looks like one will have to replace the 1.5' cable with a 3' one and use velcro ties to bundle up the excess.
Tata,
Just curious, what kind of rig/shoulder mount setup do you have for your F3 in this picture. It looks light and comfortable and I'm assuming the DP4 doesn't hurt you too much with added weight?
Tim, what do you plan to do in Slog, doesn't the HDMI go away in SLog mode.
I just picked up the new Metal SDI Cineroid EVF. After using the first Cineroid and having major issues with HDMI I would never consider any EVF with HDMI. I'm sure some other companies will offer SDI at some point but for right now the Cineroid Metal EVF is a better choice for me.
