Retrospective
Wow impressive features Mitch! Will there be anamorphic desqueeze?
Anybody notice that it has the VariCam's green-square focus feature?
For those that complained about the lack of 4k 60p 10bit the EVA1 does have 2k 60p 10bit. Thats a really good option unless you absolutely have to have 4k. Or just buy an external recorder.
For everyone who has not had the pleasure of using this function you are in for a treat. It is insanely easy and precise to focus once you get used to it, and getting there is very quick. It really works great.
"On first release, available bit rates will range from as low as 8Mbps up to 150Mbps, depending on frame rate, resolution, and codec. In a future firmware update, 400Mbps recording will be added". Future? What?
Thanks Barry, hope Mitch will clarify this...If this works the same way as on the HVX/HPX/AC/UX cameras, then it will be one button press to trigger autofocus that then "locks in" and returns to manual focus. However, on all those other Panasonic handhelds, holding the button in results in autofocus continuously operating until you release the button. That would be an inconvenient, but technically possible, way to get continuous autofocus. Obviously it remains to be seen whether the EVA1 operates that same way, or if it is strictly one-touch.
The smallest battery looks set to drive the camera for a bit over two hours, the largest battery will offer four hours of continuous use, and the batteries charge about as fast as they discharge. I believe Mitch said the camera will include a dual charger; I would guess it would be the same unit as included with the UX180/UX90. If so, that should mean charging should take about the same time as discharging; with one battery on the camera and two on the charger you should be set for all day use (and probably overkill; you could probably go all day with one on the camera and one on the charger).
Or, as I usually say, don't buy anything until you NEED it. Then, buy what you need to do the job, and make your money with it. And if you don't need it anymore, sell it on ebay to recoup the cost.Technology marches on, rapidly. To avoid obsolescence, buy your gear the day before you die.
I've got to say, whenever I've been called in to explain the functioning on something like an HPX or DVX200 or UX or something, that green-square focus is the #1 most-requested feature I have been asked for from VariCam shooters -- once they go green, they never want to go back.
For high-speed shooting, the full sensor is used for up to 120 fps. When going up to 240 fps, it crops in to a 4/3-sized patch off the sensor. Notably, that 4/3 patch will still be a full (approx) 4096 x 2160 in size, so it's possible that the 2K/240 fps might look extremely good.
Mitch -- any word on how it will make that high-speed 2K? Scaling the 4K sensor pixels down to 2K? Or pixel-skipping?
What recorder is needed to get the full 5k 10bit raw? Noticed the Inferno only does 4k make resolution from what I read. Also any idea on how long or estimate on when these features will be updated? Until they are this camera is basically just a GH5..
There's some sly math that is used where the frame is first sampled in half and then downscaled. For 2K/120p, the full 5.7K sensor is averaged to 2.8K, then the image fully downscaled from there. For 2K/240p, the cropped area is around 4.5K. This is averaged to around 2.2K and then downsampled from there. The result is high resolving 2K/HD imaging without artifacts and efficient processing. This is part of what 5.7K gets you.
impressive!
(though i wish it did employ a m43 mount so the entire gh5/m43 lens eco system could be used in combo with eva)
be well.
rob
smalltalk.productions
