saneproductions
Hi All,
I just picked up a T1i for personal use. I have some friends who do sketch comedy and I would like to collarborate with them to make a few short webisodes located mainly in a coffee shop that my friend owns. I have access to production resources as I am a producer by day with medium sized local production company so lighting/sound should be fairly easy. That said, I don't plan on doing things in a very complicated way. I will use a regular slate and a digital audio recorder with a boomed mic to do my double system. I plan to shoot in the evenings after the coffee shop is closed and need to get by with an arri softbank kit (1k,2x650,300,2x150, chimera) and a couple of misc other heads as needed such as a 2k fresnel or 1k fresnels.
I have some Leica lenses that I plan on using with the T1i (shooting 720p which is fine for the web).
I got this adapter (with focus confirmation)
http://www.fotodiox.com/catalog/product_info.php?products_id=340
Leica Lenses
35mm Summicron F2 (56mm with crop)
50mm Summicron F2 (80mm with crop)
60mm Macro-Elmarit F2.8 (96mm with crop)
135mm Elmarit F2.8 (216mm with crop)
180mm Elmar F4 (288mm with crop)
180mm Elmarit F2.8 (288mm with crop)
Questions:
Do I have enough coverage with these lenses?
Are these fast enough to use on this camera for a short film?
Wide Angle:
It seems like if I had a superwide I would be covered. I was thinking of renting/buying the Canon 17-40L F4, but this won't work because it is too slow right? Suggestions? I can't really go out and spend tons of money on another lens right now as this is a "just for fun" project.
Would I be better off just borrowing an HVX200 or HPX500 for the shoot?
Post Production:
I plan on using the advanded format conversion process in compressor to convert all footage to DVC Pro HD 29.97 before editing and finish as normal.
Leica Lenses
Questions:
Wide Angle:
Post Production:
