chabereaux
Hey Forum,
I've got a problem. I shot material with the HVX in DVCPRO HD
and want to edit it with Premiere CS3 Running on Mac OS 10.4.10.
I'm trying the Raylight way, but I got problems:
(I'm using the Demo right now)
If I put my MXFs through Raylight it processes them
and I get the Link files. When I'm trying to play these
with quicktime, the output picture is only white.
When I try to import them into Premiere it says something about
the missing codec.
I've tried installing Medie100s DVCPRO codec, Avids
and (after some search in the net) Apples DVCPROHDcodec.component.
Still not working ... maybe I'm doing something wrong while "installing" the codecs
Or they need to be placed somwhere different for premiere, or the versions i got are flawed?
Any suggestions?
I need to edit the stuff NOW and it NEEDS TO BE DONE with Premiere,
so "use FCS" is out of the way ... the solutions should be much more expensive than raylight (avout 100 bucks) OR best SHOULD be the raylight solution but WORKING.
I'm really going nuts here, so thanx a lot for your help.
Ben.
the missing codec.
Any suggestions?
Ben.
