David Newman
agwah said:great,
what is required from the storage drives in terms of transfer speeds etc. does it vary depending on the viewing resolution, or is it dependent on the file itself
I assume all of your above scenarios are running from the same 4K file
RAID-0 with two drives is all you will need. Yes the disk bandwidth is the same for all decoded resolutions as they are sourced from the same 4k source files, but the CPU usage varies greatly with resolution.
