David Jimerson said:Actually, thinking about this more, you'd want to use "blend" all the time. If you're deinterlacing 60i, using "blend" for little motion and "interpolate" for more motion is the right way to go, because 60i isn't comprised of frames; it's comprised of fields, and each field is a separate moment in time. However, 30p, even though it's written to tape as 60i, is comprised of frames SPLIT into fields. "Blend" takes field A and field B and combines them into a full frame, which is what you want. "Interpolate" takes a single field and makes a whole frame out of it. Now, you can do that, but you'll be sacrificing up to 50% of your resolution if you do.
cineasta_dom said:Quick Question.
Can 30P be transfered to 35mm for proyection? Where would those extra 6 frames go?
I'm having issues with something I recoreded in a "flash motion" digital effect that looks to be 30fps (p/i) on a sony cam - I think its 30i though... confused.
Sorry to extend the thread.
Jarred Land said:Digital Film Group is up here.. glad to know James reputation is so great down there.
he did the film out for Art history back in the day for the Whistler film festival.
Anyways.. James himself warns against shooting at 30p on the JVC.. well 30p in general.
its not a pretty format to push to film.
