Azmyth
Hi.
I'm a former professional wrestler, current musician, budding actor, and now beginning film maker.
I am wanting to film low budget indie horror shorts and features. In order to do that I want to purchase a camera. I do not have the option of renting, due to my location. Film and production is not prevalent here, which is why I am trying to "cause a scene".
I've done loads of research on what camera will give me the best results for the money.
I've narrowed it down to the following:
Panasonic DVX100 (any of the 3 variants will be fine.. )
Canon HV20/30 or 40
I've also narrowed it down to the following pros and cons...
DVX Pros:
Lots of manual controls
Has been a standard in many of the same types of films I want to create
Professional Look and feel
24p film look
XLR audio
DVX Cons:
Older camera, many claim is on its way out.
Standard Definition
Still expensive for its age compared to the other choice
would have to purchase used
Cannot afford any accessories outside of the camera at first
Canon Pros:
Newer camera
High Definition
Lower priced than the DVX for camera only
Can purchase NEW
Would be able to spend the extra money saved on accessories
Canon Cons:
Consumer camera, looks almost like a toy
lack of manual controls
no XLR audio
need good pc to edit footage
Now, given that. I've seen footage done with both cameras. Impressive stuff can obviously be done with both. My reservations are this. The DVX is older, and shoots in SD.. but obviously still is capable of creating amazing footage (SIMILO).. but, if SD is on its way out.. wouldn't it be a waste of money? On the other hand, the Canons shoot in HD... but are by no means professional cameras. In order to get the same look I'm undoubtedly going to have to buy a DOF adapter and 35mm lenses for it, plus a rails system.. easily making the canon cost nearly as much or more depending. At the same time, I'd most likely want to buy the same for the DVX anyway.. boosting its cost even higher. However, those are things that I can do without on the DVX until I can afford.. where as on the canon I almost need them out of the box.
I want to submit to festivals and attract decent people to work on my films (not just friends and family) and I'm afraid the canon will deter them from wanting to work on my films. I've seen some of the canons with all the fantastic extras.. and they honestly look more sophisticated than the DVX (albeit smaller) once pimped out.
So, I'm stuck between which camera I should put my money on.
I thought about getting the canon, and adapters.. simply because if the DVX is on the way out, and I can achieve the same results with either camera.. I could always update to a better HD camera later, and I'd have a plethora of lenses and such to use on it as well already.
I just want something that I can learn on, get alot of use out of, and make look good via lighting and good audio and be taken seriously with. I know that I will get those things from the DVX... but for how much longer?
Canon HV20/30 or 40
DVX Pros:
24p film look
XLR audio
DVX Cons:
Standard Definition
Canon Pros:
Newer camera
High Definition
Can purchase NEW
Canon Cons:
no XLR audio
