G
Guest
Guest
Anyone have this problem? I have the stock battery and the Panasonic D28 2800mAh battery. At times I turn the power switch on and get nothing. I can turn it off and back on numerous times and get no response from the camera, like the battery is dead. I can then detach the battery and replace it again and flip the power switch. The camera then powers up as normal. This happened several tiems with the D28 battery so I thought it was just a problem with the battery but it did it a few days back with the stock 1600mAh battery. This problem is intermitent as well. I will happen once and not happen again for a few days or a week then I get it again. Since the problem has happened with both batteries attached I am now assuming it is the camera. The batteries always have a good amount of charge left when this happens. Anyone else having this issue?
