If this has already been posted then please mods delete this post, this looks like a recent review of the AF100 :-
http://www.dvuser.co.uk/content.php?CID=246
Is that a phrase in Europe? He uses it multiple times. Is our version a shortened version?which made achieving narrow depth of field next door to impossible...
Uhhh. I'm pretty sure a Panavision Millennium and a 5DmII are not the only options.A camcorder with a large sensor also makes pull-focus shots more obvious and easier to achieve. We have wanted a camcorder that can do this for 20 years or so, but because there is no such camcorder (unless you can afford to hire a Panavision 35mm film camera), we have been forced to use camcorders with tiny sensors, or more recently and worse still, DSLRS; until now that is!
I know what he meant, but somewhere a sound guy is freaking out.The AG-AF101 is a serious digital SLR killer. It is a PROPER HD camcorder. The big deal (and this is a very big deal) is that the AG-AF101 uses a full size 35mm MOS sensor, well almost 35mm size.
Hahaha, question solved.The nice people at Panasonic UK were kind enough to send me one of two preproduction prototypes of the all-new AG-AF101 HD camcorder.
Yep. That's pretty much exactly how I feel about it. :thumbsup:this looks like a recent review of the AF100 :-
Give us a few weeks, you'll see footage.Awesome. Keep the reviews coming.
Okay, don't make me beg... let's see some footage.
Yes he's from Europe. The AF101 is the European model, and DVUser is, I believe, based in Europe.The DVX100b was a benchmark for 25p? Is that true? Is he from Europe?
yes that's what that means. m43 lenses, 43 lenses using the adapter, and -- very likely, Canon and Nikon lenses through the Birger adapter when it arrives. That isn't known for sure, obviously, but it's what I've been asking them for so I do think it's likely.Does this photo mean micro 4/3 lens focus control is now back as a spec?! (see focus/iris port) If so thats amazing.
All separate controls.Looks like the same wheel controls aperture and focus and WB/ISO, instead of having separate controls- maybe Mr Green can confirm this?
my god FINALLY a thorough review with someone that doesn't skirt every issue for political reasons (Bloom's intentional vagueness on many questions including dynamic range as compared to 5dmkii, etc).
Thank you for explaining.
I am still bit surprised by the position of the ports in the back and the placement in a recessed compartment of the battery. I think HD-SDI/battery location will prevent mounting such units as KiPro Mini, or even lager wireless receivers in the back without some rail system. Also there was talk of possibility of AB setup (for Dionic batteries with adapter plate), but taken into consideration size of Dionic or similar batteries (IDX) any such plate will block the access to HD-SDI or HDMI. So there will be an issue with powering such units as Ki or Nano, as they utilize D-tap connection on adapter plate. So unfortunately looks like there is going to be no possibility of using industry standard 12V batteries.
