David W. Richardson
Chapelgrove Films
Looking for an inexpensive DVD authoring program that burns progressive scan discs.
Any suggestions?
Any suggestions?
Can you export m2v (mpeg2) and ac3 files out of Vegas?
...the render templates in Vegas Movie Studio HD 11 for "NTSC DV" and "NTSC DV Widescreen" are set to render as interlaced, and there is no way to modify them. ...but my footage was shot at 30fps progressive.
That's because the DVD specification is for interlaced. DVD is SD, which is 60i (that's 60 fields a second, and interlaced) or 24p. That's all. Your 30p footage will be transcoded as 60i. Flags (in the DVD meta data) will be set to tell the DVD player that the two fields are actually a single progressive frame. Same thing that's done with 24p sources. Shouldn't loose any information, should display just fine. Mine always does. Try it and see.
If this is the case, then how should I render out my footage shot at 30fps progressive?
DVD compliant MPEG-2.
Of course. But at 30fps or 24fps? Interlaced or progressive? I want the best DVD image, which probably means giving DVD Architect Studio a file that it doesn't have to recompress.
30p believe it or not. As I said above, it should transcode into 60i, and set the metadata flags so the DVD player will pull the two 60i fields together into a single 30p frame for the HDTV to display. One more time -- try it and see.
