DVCPRO-HD vs DVCPRO-50
Does DVCPRO50 support the squeeze mode in the HVX, so the final DVD will be in 16:9 ?
Is there any way to get the variable frame rates in the 720p mode converted to the DV50 mode, for best quality and slow motion in SD?
Yes. That's the combination you'd want to use for best quality DVDs.
Not through in-camera, but if you downrez in post you should be able to get approximately DV50 quality from downrezzed 720-HD.
variable frame rates are only availalbe in 720p?
Barry,
question regarding the D-50 keyed mov you posted:
Your original frame grab looked better than the mov.
I'm seeing banding like what was in you D-25 frame grab.
Is it just me?
Your frame grab difference was night and day. DVCPRO-50 looks great.
You didn't accidently post the a d-25 mov?
Thanks, Steve
Stevet said:
Your frame grab difference was night and day. DVCPRO-50 looks great. You didn't accidently post the a d-25 mov?
Don't think so... I posted the file that the compositor gave me.
Back on the subject of DV50 vs. HD -- some people are going around saying nonsense like that the HVX isn't resolving more, or that it's using DVX100B chips or some other prepostery (like that word? Just made it up.)
So here's a shot that shows DVCPRO50 and DVCPRO-HD, shooting the exact same scene (again, only thing changed was the recording format). Then I blew up the DV50 shot to 200% so it was approximately the same size as the DV100 shot.
variable frame rate workaround?
so how can I do variable frame rate work for dvcpro50? -shoot that in in 720p and downconvert? -in fcp??
thanks, soren
Yes thats correct. Like Barry said above, if you down rez in the camera you will take a quality hit. As far as I know FCP will do a good job down rezzing. But there may be other programs that do a great job ..I don't have Final Cut, but I read somewhere it does a good job. I think it's still early to decide which NLE is going to work best for me.
I'll add this question onto this thread since it kinda fits.
I got my HVX but I don't have a p2 card yet. I was playing with the settings and wanted to know. Can I shoot DVCPRO-50 in real 16/9 and what setting is it on the HVX, I see Normal and this seems to make it 4/3 then there is squeeze and lettebox.
Wouldn't normal be 16/9?
\v
Use Squeeze. In squeeze mode all of the pixels on 16/9 chip will be used.
DVCPRO-50 is SD which is normally 4/3. So to get all of the HVX 's chip into the 4/3 format it is "squeezed" thats how I think of it anyway. You then tell your editing system to stretch it back out by rendering as "Widescreen" . The DVCPRO-50 is very rich in color and the added resolution is very noticeable even when burned to DVD. I did it, I can see an improvment over a standard DVD using DV codec.
"norm" = 4:3
"squeeze" = 16:9
"squeeze" uses the full surface of the CCD and provides the highest rez the camera can deliver in a standard-def image.
So is in camera downressing to SD worse than a normal SD capture, or is it just FCP thats better. The normal SD capture is downressed from the 1080 CCD reading anyways, right?
Barry_Green said:
I don't think Walter's assessment is correct at all in this case. We did some keying tests with DV50 and it is so astoundingly superior to DV for keying that it's silly to even think about using DV for keying. I'll post a clip sometime tomorrow that shows what DV50 keyed looks like.
DVCPRO50 is the real deal and is substantially, notably, significantly superior to DV for anything where color changes or color borders appear. QUOTE]
I would never consider using a 4.1.1 (DVCPro25) recording for chromakey, a 4.2.2 recording such as DVCPro50 has twice the chroma resolution.
Panasonic Sales rep should pay you some cash, or at least some free tapes. I have not seen a better reason to Not get a DV/HDV camera and instead go with a HVX to shoot SD at DVCPRO-50 or the DVCPRO-HD. I am sure a similar test would show HDV looking like the DV sampling, perhaps even worse. Thank you,
