Hmmm. Just realised that DVCProHD footage should have about the same level of quality as DV . . . .
Hmmm. Just realised that DVCProHD footage should have about the same level of quality as DV since HD is roughly 4 times the resolution of SD and the bandwidth the codec uses is 4 times as much. Cool. But that's about 52GB per hour of footage!
I don't think so - though it's not as straightforward as it used to be.DV has 1/4 the resolution of DVCProHD
DV uses 1/4 the bandwidth of DVCProHD
Therefore the level of compression,
and hence the image quality,
should be about the same for both codecs?
