B bweaver New member Jun 13, 2006 #1 I have a 1.67 mhz Powerbook. Can I edit DVC Pro HD on this as long as I have a fast enough drive? If so, will firewire 800 do? Or will it have to be SATA?
Drew599 Veteran Jun 13, 2006 #2 You should be able to. Do some tests before you have to do anything where you need it done right away.
THE HONEST LIAR Active member Jun 13, 2006 #3 Yes you can Bweaver. Check this thread it will make for good reading. http://www.dvxuser.com/V6/showthread.php?t=54493&highlight=STRESS+TEST Kind regards THE HONEST LIAR
