chwfilms
I recently wrapped shooting a feature using 3 HVX 202 cameras shooting in 108025P. I own and have operated an HVX 202 for over a year now and have faultlessly used the P2 software to injest footage. At any time I can play footage with the P2 data manager. The Director on this feature chose to cut this film on final cut so I decided to hire three macbookpros to handle the footage. There was an understanding that the P2 software was compatible with Mac. My goal of using the P2 software was so that I could call up at any time any shot and play the rushes.
While using the p2 software - What a disaster! The Macbook pros repeatedly crashed during the 16 gig injest- also the PMCIA adapters are extremely fragile and unreliable - we had two fail - they are large and chunky and also require the mac to reboot each time in order for recognition. I almost pulled the pin on Mac and reverted to PC right there and then - had it not been from the brilliant work from my data team.
We were forced to drag and drop the files directly to the hard drives. The only way I could access and view any of the rushes was to open final cut and then seek the video files and drag them onto the time line. Nontheless - the feature is in the can or should I say hardrive - all four terrabytes of it.
The drag drop work flow was effective and proved 100% reliable for the feature production requirements. I would of preferred to have the easy viewing feature of the p2 software - despite this we got the sucker in the can!
My advice, opinion to anyone out there - only use PC for file injesting (if you want to use the P2 software) - when you come to the edit and want to use final cut, then simply convert the files to the Mac Platfrom prior to cutting - stick to a PC with an onboard PMCIA.
CHW
CHW
