Samuel H
Major Contributor
This Friday I had a big shoot and I should be editing but I'm mentally tired and doing all sorts of things just so I don't sit down and edit. Like: I just spent three hours running DR tests to see what Sony and Samsung and Nikon could give us if they wanted.
This is a summary of the results.
* I set the a7S to slog2 (Flaat) and shot some video and RAW stills tests. The RAW stills ahve around 1.25 stops more DR than the video footage. In particular, video loses one stop of DR in the shadows, in part because the internal codec kills some texture detail, and in part because slog2 is not as aggressive as it could be. The part that is due to the codec -no idea how big it is- should be solved by recording external 4K ProRes HQ.
* Then I set it to "no PP" and shot the RAW stills tests again, at ISO 3200 and ISO 800. Slog2 has two extra stops in the highlights wrt usual picture profiles, so my guess here was that slog2 ISO 3200 is just ISO 800 underexposed by two stops, then remapped with a different gamma curve. The results support this. The no-PP 800 stills look a lot like the slog2 3200 stills, whereas the no-PP 3200 stills have a stop and a half less DR (also, they have clearly less DR than slog2 video; therefore ISO must be, electronically, a different thing when using slog2 or no-PP).
* Just for fun, I ran the test again with "no PP" and ISO 100. This has 1.25 stops more DR than both no-PP 800 and slog2 3200 RAW stills. This tells me that the a7S could record at ISO 400 or 800 using a profile that's even flatter than slog2, and it would have between 1.5 and 2 stops more DR in video mode than it does right now. Even if the a7S has more DR than most of its competitors, Sony is holding back on the DR front.
The a7S could shoot slog2 at ISO 400 (elecronicallally-same-as-no-PP-ISO 100). It would have the same DR as it has now, maybe with a bit less noise in the shadows.
With the same settings (elecronicallally-same-as-no-PP-ISO 100) and slog3, it would be ISO 1600 and it would have around two stops better DR than it currently has (1.5 because of slog3, 0.5 because of less noise in shadows). I would overexpose it by one or two stops, and treat it as ISO 800 or 400. If it is kept at 8-bit, on the upper side of the curve it goes from 29 values per stop of light to 20 values per stop of light.
* I ran the tests with my NEX-5N too, at ISO 100, with RAW stills. It came out 1.5 stops short of the a7S at ISO 100, and half a stop short of a7S at no-PP 800 (or slog2 3200). According to dxomark the difference should be between 0.3 and 0.5 stops. I suspect the dxomark method is hurting the a7S relative to others for some reason, just like I think it's hurting the NX1. You have to decide many things when measuring DR, it's far from straightforward or purely objective. For example, I decided highlights are only usable if they are correctly colored: washed out highlights didn't cut it on my test, skin goes funny when that happens to it. But for clouds this wouldn't be an issue, and counting desaturated highlights as usable would probably change the relative results. The usual DR target test is monochrome, and this includes the one dxomark uses, so this could be the source of the difference. I designed the test to fit *my* needs.
* The problem with the unused power of the a7S is that Sony is unlikely to unleash it: it has to protect its higher end cameras. But Samsung doesn't have that "problem". And according to dxomark the NX1 at ISO 100 matches the DR of the a7S at ISO 100. So, those 1.5 to 2 stops more DR can come from Samsung if they release a wider gamma curve that doesn't clip any information coming out of the sensor. I know this would lead to banding issues and whatnot, but I'd rather fight banding than clipped highlights.
* A hack that records RAW on Nikon DSLRs would be really huge. According to dxomark, the D810 has 1.7 stops more DR than the a7S shooting RAW stills at ISO 100. Maybe the dxomark procedure is hurting the a7S relatively more than others, and maybe that'd be just 0.7 stops with my methodology. But also: RAW doesn't have these 8-bit-related issues the NX1 would have, nor the compression issues of the a7S slog2 video. a7S RAW stills at ISO 100 already have 2.5 stops more DR than a7S slog2 video. With a D810 shooting RAW video, I believe we'd have 3 extra stops over the a7S slog2 video. Mouthwatering.
