Down grading HDV to SD, with FCS 2
Eatsnax
Hey guys I did a search and I didn't find info that told me how to do this. I shot in HDV 1080i. I have to give the footage to someone who needs it in SD format, 480i or 480p. What is the best and simplest way of doing this? I have FCS 2 and I also have Vegas. I rather do it in FCS since Compressor is easy to work with. I'm hoping there is a solution that I can do in just one pass, instead of having to dump the footage in HDV then rendering in a timeline.
Any help would be greatly appreciated.
Thanks!
Use the DV lock in the camcorder, downconvert as SD out of the camcorder, edit and render out as 480p by de-interlacing using blend the fields method.
Thanks, I'm looking and looking and I see nothing that says 'DV LOCK' I do see in Play/Out setup2 that you can set Comp Out to 480i, is that it?
I figured it out looks like the only way for that option to light up so you can adjust it is when there is no firewire hooked up. I was trying to find it while the firewire was plugged in, and as soon as I unplugged it it lit up.
