Rick Burnett
Section Moderator
The Alexa does the cyan shift as well, just not as bad. The way I found this out was I watch the show Fringe and happened to notice cyan around the lights in one of the labs in the show. I was like, wow, that's strange. So I head over to IMDB curious to see what they shot with and I see they switched on the season I was watching to an Arri Alexa. The fact I noticed the highlights changed in the show VERY easily was VERY interesting to me.
The problem is, when you get these situations is that what you are wanting to do is ramp all 3 colors to max if ANY of the 3 colors approaches max. I started a plugin for this for AE/PPRO but the problem I was having is the compression being used ruins the edges between hl color shifts and dark edges. 4:2:0 especially. It's basically desaturating the highlights.
In studying the 7D this is what Canon seems to do on the DSLR.
I've not used the C300 enough to know what the codec is like, but if it is 4:2:2 then it should be MUCH EASIER to fix this. Although the problem some area dealing with on the rainbow edge, that is not as easy to fix, although there is one pretty good solution if needed earlier in the thread.
