The problem is, at 6'4", even if the camera is resting on my shoulder with NOTHING inbetween it and my shoulder, it's too high. The majority of people I shoot are always quite a bit shorter than me, therefore, my only option is to squat down to get the right angle I need.
Kholi, what's the weight like without the "gut-stick" ?
One of the main reasons I've always liked the Zacuto shoulder mounts is that they have enough counter-balance weight that the camera can pretty much float without tiring out your arms when shooting all day.
01-18-2012 02:40 AM![]()
Woah, just stumbled over this here:
Never heard of that company .
The website is a bit errr... quite though.
http://www.aeoncine.com/
The best information I found is this: http://cinescopophilia.com/a-sneak-p...-shoulder-rig/
Frank
90% of the photos I see on here are people shooting shoulder mount. I thought, okay, I've not really shot a lot of shoulder mount so let me try it. I've been through 2 iterations of shoulder mount setup and the honest truth is I just don't like it. Given I am 6'4" most people are shorter than me. This means for almost every shot, the camera is pointing down a bit. If I get down on a knee or knees, then I am stuck in that one position.
When I see a lot of film set shots, I see the camera either on a tripod, or, they've got it on a crane/dolly system that is typically pretty crazy.
When I used to shoot with my 7D, I used a blackbird stabilizer. I have to tell you, this combination was absolutely amazing. EVERY person who I've taught to use the setup has just been amazed at the freedom in shooting so they get more dynamic shots. Because the camera is right in front of me, my arms work raising and lowering, and I can track and rotate very well with the system.
Then I bought the FS100 (and before that the AF100).
These cameras are just a bit too heavy to hold out in front of you all day long. (The AF100 more so) and because both camera are longer, the weight distribution at the top isn't as good to me with the Blackbird.
I've spent DAYS thinking about this. I know when we shot with the HVX200 that we'd use the top handle for lower shots, and cradle the camera for midlevel shots. And of course, hand held for higher shots.
With the FS100 and AF100, I don't know why, but handheld with the built-in/attachable grips just feel off. The weight is all wrong on the FS100. On the AF100, the lack of articulation in the grip prevents me from using it at different camera heights.
I've been thinking of using my Berkey pieces (with some additional ones) to build a bunch of different grip points around the camera to help with holding it. Making it so I can change the grip location based on center of gravity AND the grip orientation to deal with the axis of rotation relative to my movements.
Some people have used a camera strap to help stabilize when running with the camera lower. I also considered if a chest pad in the back would help.
Has ANYONE gone down this path? If you need to shoot a mid level (think camera at stomach) shot where you need to move around, what do you do? Any ideas would be GREATLY appreciated.
Another trick I like to use for static handheld shots is sticking a small bouncy ball in the Mitchell plate, or the bowl of the tripod. This way the operator can rest the camera on something, but give the shot that handheld feel. I also like to do this with dolly moves that I want a little loose. This way you don't feel the obvious steps of the operator, but still get a good push in or pull out.
There was a website a while ago about the operators and grips on the wire, I think it was. They had developed a soccer ball with a lockable cage around it, that had a quick release plate on top. Cameras would be handheld all the time, but they would always stay on the dolly and could be locked off when not in use.
Ulitimately I think when Tom Cruise calls we over six footers may need to turn him away..
Have fun
Samm
