Inprogress
Bit or a general question related to any camera.
If you use a ND filter, or a variable ND filter, do you need to use (or want to use) a Polirizer? I will be one of the camera men next year for a local motorcycle navigation/endurance rally for the big trailies (450cc and up). The route is then obviously outdoors, and I believe there might be some sand involved (route kept secret till the day), although not beach scenes, some dunes sections - cannot confirm, based on previous qualifiers. I was thinking of merely using a ND filter (thinking of a Tiffen set, or to try a Polaroid Variable to see if the variable thing works for me workflow wise). Then the thought crossed my mind about a CPL and whether it is needed if I use the ND's.
There will be some wide angles and for that I will not use a CPL, but in general, is it needed (apart from avoiding to stack filters anyway) in terms of how the light is registered and glare etc? I suppose its two different applications. If you want to remove glare and lessen light intensity a tad bit due to the inherent use of the filter, use a CPL. If you don't mind the glare but want to lessen light intensity to gain shallow depth of field, use ND.
Thank you for the advice from those in the know.
EDIT: P.S. The one thing that bothers me about using a CPL is the possible banding issue I might encounter with the sky - talking from lack of experience here, just a concern I have read about but not had the chance to test for myself.
