Imamacuser
Has anyone tried something like the Tilta seamless focus gear rings with stiff vintage lenses?
I'm concerned that they'll slip.
From my experience, slipping isn’t usually the main issue, it’s more about inconsistent resistance depending on the lens. With stiffer vintage lenses, they can feel a bit jerky unless the gear fits really tight, so it might be worth testing one before committing to a full set.fnf If you've never used a solid mechanical system with very smooth precision, ones like the above could work for basic adjustments (short turns in an interview if the subject moves forwards or backwards an ich or two, etc).
Some lenses work better with them than others and I think the main issue is friction and locking up rather than slipping off, just might not be able to get a smooth throw in certain situations (and the system working with them matters too).
Are we saying the same thing? (Or maybe that was supposed to go to the OP.)From my experience, slipping isn’t usually the main issue, it’s more about inconsistent resistance depending on the lens. With stiffer vintage lenses, they can feel a bit jerky unless the gear fits really tight, so it might be worth testing one before committing to a full set.
I've had it happen with a stiff Tamron zoom when using them as zoom gears. Never had a problem with them as focus gears. Fixed the issue with the zoom with a 2 mm smaller diameter gear. Soaked in very hot water to enable a bit more flexibility. That worked to get it on. Didn't slip after that. The biggest issue I find is if using them on E-Mount, or basically any other photo mount that doesn't have a solid, a la PL mount locking strength is movement. The front of the lens must be very securely locked down to avoid any lateral, rotational and lift movement of the lens when adjusting the follow focus. Because if it's not solid you will notice slight image shifts as you apply torque either way on the follow focus gear.Has anyone tried something like the Tilta seamless focus gear rings with stiff vintage lenses?
