you only have SD out, so for fine focus its nearly worthless to spend the money on an external monitor. all externals with HDMI or composite in will work.
Use the low angle Varavon ( ask first and see if it would fit) or Zacuto, with the Zacuto you have to use the sticky frame, just don't swing the lcd out with the viewfinder on, because I don't think the hinge is strong enough to support it, I remove my Zacuto before I swing it out, it is a little pia because you have to hold the lcd to pull out the zacuto, but I think the Varavon is much better design, I think I will get that one my 7D.
