ChrisHarding
Hi Guys
Coming from 2 x HMC80's I really struggled with the smaller AC-130's when handheld so I have them both on shoulder mount rigs nows. Essentially it's just 2 simple 1/2" aluminium tubes with aluminium flat bar for camera and tripod plates plus some really useful grips at the front end. The rails offset at the end and have a neoprene foam block with a curved cutout so it sits neatly on my shoulder. The added advantage is that I also have radio receiver mounts sitting just outside the battery compartment so that saves having them on the camera handle. using just the LCD is fine inside but a disaster outside so I grabbed a Hoodman loupe and fastened it with rubber bands on the LCD for a perfect solution...unfortunately the loupe weight tends to twist the LCD so I have also made a little "crane" that extends out from one of the 1/4" threads on the handle and that hooks into the lanyard "o" ring of the loupe and takes all the weight off the LCD so it floats there...the bands simply stop it from moving. Works very well and I can now shoot from the shoulder without any issues!!!
Chris
Chris
