DIY indislider
Absolutely stunning. Native lens? (I know you had some RR stuff posted earlier)
None of what you've posted IMO seems out of the ordinary. All looks very clean and very acceptable.
Going to try to hit some colors here in Utah before the middle of next week. Absolutely my favorite time of year.
yup, that's with the stock camera.
This footage actually looks better than some of the other stuff I've shot as far as noise goes.
Had you changed any of the profiles? Gammas?
My guess is most of those coming from the HVX are expecting it to be exactly the HVX sans tape carriage and while Panny pretty much touts it as that, seems like it is its own beast and just requires some TLC beforehand.
I'm working with some A1 footage right now and noise is definitely there with ND on, some very similar to what I've seen here.
Here's the scene file I used
starting with detail level
+1
+1
0
+4
0
-3
-3
-18
0
Cinelike V
Cinelike
yep. footage looks really good especially with the slider!
Do you have any pics of the slider?
yup, here it is with a 200 on it.
You can asseble your own in a flash with 'linear sliders' It's available from many sources. Do a search and see the infinite products available.
IE: http://www.nbcorporation.com/pdf/NB_Linear_Systems.pdf
Just take a look at the single or double rod slider. They are SUPER PRECISE and smooth as a 'spit on the door knob' as they say down under :)
You can also look in surplus sections and other sources for these linears.
I may throw one together in a flash :)
Another source for mfg: http://www.bearings.machinedesign.com/AllVenPage.aspx?pcode=305-W703&fn=Linear+Bearings
Haven't weighted it, but it is real light...easy on the back. I have a good 36" of travel, how long is yours? (that just doesn't sound right!):huh:
not sure, I'd say probably around a foot and a half of travel. It's heavy as hell, I may end up building another one that is lighter if I can find the right materials.
Would you mind weighing your and posting the weight? I'm interested in your track because mine is heavy as hell.
ZazaCast seems to have the ideal set up. Mine is larger rail and a much larger slide block. I'd be Zaza's is at least a pound lighter than mine.
The rail & carriage (on a bathroom scale...it's all I have) weighs about 5lbs.
It's really not tough to move around at all. I love the thing and find myself using it all the time now. I built it for "An Enchanting Twist Of Peccadilloes" and it turned out to be a dream to work with....so, I then shot my second TwilightFest entry "TWISTED" and used the slide. It was great to just leave the camera, which had the Red Rock M2 on it, attached to it all the time. Even if I didn't use it for moving shots, it gave me 3' of play for framing shots without having to move the tripod. Really handy.
Oh, and note, I just throw a 15 lb. sandbag on the bottom of the tripod and I can slide all the way out to the end...no problem. It even lets you slide right to the end and pan the camera 90 degrees straight down! This come in handy sometimes. You'll be able to see all these different shots in my fest films!:beer:
wow man. Great footage.
So clean.
I dont see what all this fuss is about noise personally. I'm really happy with the 170
Wow, surprisingly smooth! Again, like your composition.
Those almost all of your dolly + pan + tilt shots were perfectly executed... supa-cool.
