Kholi said:Not sure who said it was unacceptable or unusable.
Check the first post in this thread.
kevinM said:Check the first post in this thread.
Scrappy said:I don't think the issue of low light and the hvx is noise, it's just the darkness that I can't seem to fix. My experience so far is any interior that is not well lite just looks dark. My previous camera was the dvx100a. I sold it when I got the hvx but am now tempted to buy another one for interior night shooting.
Justyn said:That's the one thing. This format allows for lots of messing with.
I thought A1 could be better in low light when I found NR1, but after playing with it, I gotta give that particular function the thumbs-down. It causes ghosting in pans, etc. It cleans up noise, but the tradeoff isn't worth it, and besides you could always do noise reduction in post if you wanted.Kholi said:When you could go A1 and get great lowlight performance and an HD-sized image.
Barry_Green said:I thought A1 could be better in low light when I found NR1, but after playing with it, I gotta give that particular function the thumbs-down. It causes ghosting in pans, etc. It cleans up noise, but the tradeoff isn't worth it, and besides you could always do noise reduction in post if you wanted.
So I go back to my original position -- XHA1 and HVX are equivalent in low light.
Probably exactly the same way. Just saving a generation of uncompress/recompress by doing it in-camera.Kholi said:How does noise reduction in post stack up to in camera, though? Is NR1 accomplishing the noise reduction the same way as it is inside of the A1?
That's exactly the point. In-camera does something else to the image too. There is no free lunch. If there was no side effect, they would have enabled it by default. There is a side effect -- ghosting. You get more ghosting the higher you turn on the setting, but you get ghosting on any setting. Whether in-camera or in-post, it's the same basic technique. NR1 is useful only for a static shot, or if you don't care about the potential for ghosting.I personally do not know of any post options that reduce noise without doing something else to the image.
It's not a stop and a half faster! It's more like 1/4 stop faster, if that. So yes, if you want to look at 1/4 stop then yes, it is a little bit faster and that tiny bit better. But I'm saying fundamentally equivalent.And you're saying equivalent... I guess you'd know more from having both side to side but it just doesn't look the same, to me. The Stop n'a half or so that you reported (Correct me if I'm wrong! Not sure) from the A1 still makes it that much faster in lowlight. Right?
If in-camera NR creates ghosting, it will be very difficult if not impossible to correct in post, so I'd rather let the camera shoot a noisy image, and fix it in post. You'll get control over the level of NR, and you can reduce it or leave it off during during motion when it is less noticeable to the viewer anyway.Kholi said:How does noise reduction in post stack up to in camera, though?
THoff said:If in-camera NR creates ghosting, it will be very difficult if not impossible to correct in post, so I'd rather let the camera shoot a noisy image, and fix it in post. You'll get control over the level of NR, and you can reduce it or leave it off during during motion when it is less noticeable to the viewer anyway.
