They have both vertical and horizontal models. I like the horizontal model shown here.
I think it's time to upgrade/source a better improved slider with roller bearing for smoother operation like the dpslider.com. You should get on it Joe.
I just built mine a couple of days ago and have realigned the bearings as per the instructions, but it still seems to "bind" - stick in parts - as I slide.
You shouldn't have to. Again, it doesn't sound like you aligned the carriage properly.Couple of questions about getting the best slide:
Is it best to slide back the carriage multiple times, back and forth, to build friction and "smoothness" before attempting a camera move?
It's a good way to clean the rail every now and then. Spray a little on a cloth and wipe down the rail...then wipe again with a clean, dry cloth. It won't hurt the bearings.Is there any validity in using Pledge on the rails, or will that just ruin the dry bearings?
No, you shouldn't have to leave any of the bolts loose if the carriage is aligned properly. Please try again and go slow... loosen all bolts with the carriage on the track and slide it back & forth a few times. With downward pressure on the center of the carriage, tighten one bolt, just till it's tight. Again, slide the carriage back & forth a few times, then, with pressure on the center of the carriage, tighten the opposite bolt lightly. Repeat this, tightening the bolts opposite each other (start with the upper left, then the lower right, then the upper right, then the lower left) until everything is tight and it slides nice & smooth.Is it best to leave the carriage bolts only slightly tight so they can give a little?
This morning i was having this issue...
i think my ZAZA"GOD"SLIDER wasn't working perfectly from a while, so i had the bad idea to remove the carriage and accidentally i moved a little bit one of those 4 metal objectes that stay on the bottom of the carriage(how do u call them?). Then i tried to set the carriage back to the slider and seemed to work properly. After a few shots i'eas looking in the slider and i found a lot of grey little "tongues" as the slider is eating the bearings. What could it happened? The slider now doesn't slide like before
thx for your help guys
