Ben_B
More handles can be added underneath but I like this best because it's lightest. Stock adjusts...angles up and stays fine right now (IE camera ends up lower) but right now won't angle down and stay (camera higher) but I will be adding a second part for a bolt to go through to lock it in the most comfortable angled down position. Made from old air-soft stock, some steel pipe, a flange, and some PVC pipe. Adding a quick release assembly to top later. Works nicely for stabilization of static shots, less shakey (for GH1...reminds me of say, HVX handheld shake) running shots, and even sudo-snorricam stuff. Can hold like a rifle, shoot from the hip, hold stock and front handle, cradle the whole unit, or even shoot upside down. So far I'm very happy with results. The gaff tape on the stock helps keep it intact but isn't structurally that important to the unit...you see the stock is being squeezed pretty hard by the PVC pipe and the wing nuts on either side, and the gaff tape helps keep the two halves of the stock (it's a cheap one) from slipping, breaking their screw-mounts, and smashing together....and it's being doing great.
Works great with LCD or viewfinder, but you have to adjust the stock to move the LCD in and out...hopefully tripod quick release will help this (puts camera a bit higher and should let it quickly slide forward. I can also as of now mount the camera or the handle/cameramount further up (other holes drilled) but I like it here because it keeps weight better distributed and viewfinder in reach.
