So I wasn't too happy with the Fader Mark 2 (New version) as it seemed soft still when shot with 200mm + lens.
So I made the DIY fader (Circular Polarizer with Linear Polarizer screwed on top) using good quality Hoya filters.
I did a test shot at f2.8 using both Faders and the DIY Fader was much sharper. You can see so much more detail with the DIY. I also tested it against regular Tiffen ND filters and the IQ was the same, so DIY fader = no resolution loss.
I tested it multiple times with the same results.
The screen grab should be on this thread. if not, here's the link
http://www.builtbyugene.com/images_client/diyfader.jpg
I tested this quite a bit with different lenses. I've come to the conclusion that the lower the aperture, the softer the LCW Fader ND is.
up to 50mm, there seems to be no IQ loss with the Fader ND. At 85mm, it's a bit softer.
At 200mm, the LCW is pretty soft while the DIY version loses no IQ.
So I just use the LCW on my 55mm lens and lower and on anything above 85mm, I'd use the DIY.
I'm sure the DIY is everybit as sharp as the Singh-Ray and costs way less. Plus, you can polarize with it also which is nice. But that's a bit of a pain as there are 2 rings to turn.
