Ted Ramasola
Some time ago I posted a DIY baseplate and rail block but the difficulty of several DIYers getting the parts spot welded discouraged them. Since I'm now in the U.S. I experienced the same difficulty so I modified the designs for my DIY projects.
Now I have sourced all my parts and tools from Lowe's, Home Depot and even one item from Walmart. This design will no longer require welding.
Essential tools needed are; a metal hack saw, a drill, preferably a drill press, a way to hold the pieces while cutting, either clamps or preferably a vise and a rivet tool. Now U.S. based diyer's can acquire their parts easily.
Take note that the industry standard for rail rods are 15mm, the "rods" chueaply available at lowe's and home depot are 13mm (12.7mm) aluminum or steel tubes so for those starting from scratch and dare to have their own "standard" like me, you can use the cheaply available tubes as rods for your DIY rig. If you have an existing rod system and need compatibility just change the bit for the drill so it will accept the 15mm rods.
Here is a video showing the possible configurations of the rig based on the basic baseplate. There are still a few more possibilities but these are the basic ones.
Here is the guide to the DIY baseplate and rods.
The rail block which is referenced in almost all the accessories has its own step by step guide.
For the rail block, high res image of part 1 and 2 of the Baseplate and rods, go here. http://www.ramasolaproductions.com/5.html
