matthewwest
Hello all I'm new here, so thanks in advance for any help you can give.
I'm going to start off by saying that I'm not a professional camera man, or even a serious hobbyist. I am a CE veteran (used to run the testing lab at Circuit City, ran the company tech blog), so I know how most of this stuff works.
A few months ago I ordered an HMC150 to use for work purposes. Shooting event footage, CEO interviews and videos, etc. Trying to save the company some money. For the most part, the camera has worked fine, except for two occasions, both of which involved the CEO.
What happens is that I shoot footage, play it on the camera, then turn the camera off. I then remove the card from the camera, insert it into the card reader in my MacBook Pro, and open Final Cut Express. I start the log and transfer, and get a message about a non-supported file structure.
At this point, if I remove the card and put it back in the camera, I get a "no data" message. All of my footage is gone, and has to be reshot. CEO is not amused, and is suggesting we return the camera. I can't disagree.
I'm using 16GB class 6 Transcend cards. I called Panasonic today, and the tech guy told me it's likely a problem with Final Cut Express, even though it works perfectly fine 95% of the time. I'm wondering if one of my SDHC cards is bad, but it seems like if that was the case, I wouldn't be able to record at all, or there would be playback issues in camera.
At this point I've asked purchasing if we can return it to CDW and get a DV tape model instead. I know there's probably some logical explanation to this, but the whole memory card thing is starting to seem a bit too risky for me.
Any ideas on what might be causing this problem?
