Shutter speed does not affect the motion nearly as much as frame rate does.
Frame rate is about the number of pictures taken per second. When a lot of pictures are taken per second, then anything moving does not move very much between pictures. When fewer pictures are taken, then they move more -- seem to "jump" more from picture to picture -- than at a higher frame rate. This gives a particular flavor to the motion.
A shutter speed is the length of exposure. All it affects is the apparent blur of moving objects in each individual picture. It doesn't change how far an object moves from picture to picture. A very fast shutter speed can produce more of a staccato motion -- make it seem jumpier -- but that effect is quite mild compared to the frame rate. And the same shutter speed will give you very different effects when used at different frame rates.
The difference between 50p and 25p, visually, is that 50p looks "live." It looks "live" because the motion is very close to what you see in real life. 25p looks more surreal, more "fictional," because the motion is not what you see in real life.
50p at the same shutter speed as 25p will still look a lot more "live" than 25p will. The overall flavor of the motions is the same; the shutter speed just adds seasoning. And just like seasoning has different effects on different flavors, so, too, does shutter speed on different frame rates. But a steak still tastes like a steak, and not chicken, if you put "cajun chicken" seasoning on it.
A lot of this is demonstrated -- especially the shutter speed differences -- in the demo reel of the 24p & Frame Rates tutorial. You can download it (you must watch it at 60p, and web services don't display at that rate, so it must be downloaded) at the page here:
http://www.wrightsvillebeachstudios.com/24pFR.html
Or directly here:
http://www.wrightsvillebeachstudios.com/24pExpts.zip
Or directly here:
