LearningVideo said:The Truth:
Without P2
1) you cannot use direct harddrive to record from HVX.
2) You only can use direct to PC if and only if there is a software running to capture the output. Without a capturing Software, you cannot use a PC.
3) The capturing software on the PC is not free or cheap. You have to use a full blown NLE for it. If you have two HVX, then you need to PC each with its own COPY of the NLE software... JUST TO CAPTURE!.
4) Cineporter is not out yet. I do not know if the firestore for HVX is out. Never heard of citidisk.
I bought an HVX anyway. I am waiting until the 16GIG P2 cards are 500 each![]()
PunkMetalDrummer17 said:3. Why would it need its own copy of the NLE software to capture?.
PunkMetalDrummer17 said:4. Also, firestore is out..... you'd need the FS-100
http://www.focusenhancements.com/solutions/catalog.asp?id=150
It's a little more than the price of one 8GB P2 card and holds 100 GB.
manglerBMX said:yo can still get refurbished powerbook g4's on the apple site. and you cant use one computer to capture from two sources.
PunkMetalDrummer17 said:Why do you need two PCs though? (I don't own the camera myself....)
I thought you could just pull them into one avid.
why would you want to capture at the same time... with two PCs you would have to pull the other camera into the other system.....LearningVideo said:I wonder what would it take for one pc to capture DVCPRO-HD from two cameras at the same time?
