Are you saying they aren't the same thing though both @48Hz? Why?Elton said:IMHO, you do get a lot closer, perceivably, to full 1080 24p resolution than the other $sub-10K cameras with Canon HDV 24F.
Emanuel said:Are you saying they aren't the same thing though both @48Hz? Why?
It was two years ago regarding the Canon SD offer. Actually he compares the Canon's XL1 progressive mode to the future CF then as fake progressive.Barry_Green said:The NTSC XL1 produces a "pseudo" 30P. The PAL XL1 produces "pseudo" 25P.
The NTSC XL2 produces genuine 24P and 30P, and the PAL XL2 produces genuine 25P. But the XL1 fakes it using frame mode.
Elton said:Interesting that you should say that. I've done a lot of deinterlace stuff with Magic Bullet, Nattress, etc. and I never got perfect looking progressive results. There were always a few odd repeat frames and hiccups. 24F has never EVER shown anything that looked like an interlace artifact the way software deinterlace can.
MovieSwede said:Canon has one more benifit (as the Z1) it does the deinteraling before compression where most other deinterlacers work with already compressed material.
Of course this is just my theory, but it seems logical that they use smart deinterlacing if they capture from 48i.
Good question!Gordon Prince said:The frame movie mode available within the XL1 (SD) is the same than the progressive mode of its HD version? (XLH1 and now A1/G1 as well)
If we can say this on XL1/XLH1 comparision subject, will it be the same between the XL2 and its successor, the XLH1?Elton said:There may be some fundamental similarities in how it's achieved
Putting in another words: And already wasn't the XL1? Then, why XL2 is mentioned by Barry as true 24p and not the XL1 mode? If the XLH1 is more similar to XL1 than XL2 (if it is!... here is the question), this will be a backward step (if compared to XL2) or not?Elton said:if you're familiar with the cadence of 24p and you take a good look at 24F stuff, nobody can honestly say they truly look different.
The way I see it is this: 24F is a different path to the same basic result.
