I have tried to figure this out from the Sony specs but I just can't: When I compared output from the dual link SDI out, recorded at 4:2:2, with output from the "regular" SDI (the SDI that sits right next to the HDMI out) out to 4:2:2 (all else being equal), the difference is very noticeable.
To be clear: both recordings are at 4:2:2 and both use the same codec (ProRes HQ). I would have thought that the 4:4:4 output from the dual link would have little advantage when recording at 4:2:2, but there is, particularly with skin tones. I have now confirmed this based on 2 different, independent sets of tests.
Is there something different in the output from the dual-link SDI than the regular SDI above and beyond just color sampling?
And, if so, I wonder if the SDI-A out with the new firmware will look better than the regular SDI out.
