PatrickLawler
What's the difference between AVCHD and DVCPROHD which one is better?
basically one is a codec based in h264 compression, Long GOP, 4:2:0 color space, but capable of full 1920x1080 encoding. The other is based on mpeg1 compression, intraframe, 4:2:2, which is fantastic for post production, but its limited to 1440x1080 on PAL and 1280x1080 for NTSC in max resolution.
First, DVCPRO HD is not MPEG or anything like it. It is more like an MJPEG, but not really. It does start with a DCT and goes from there, but on a frame by frame basis. When you talk about the recorded full raster pixel map, you need to recognize that if there is any lacking in the signal or in the algorithm, it will show. You really need a codec that will support the full raster or just expect that sooner or later you will find that the compression engine will come back to haunt you.
Jan
I found this thread during a search and thought I would revive it with my question.
What is the best way to convert CANON avchd to dvcprohd? Panasonic has a utility which does this but ONLY for Sony, not Canon.
I woud rather not go through ProRes just to get to dvcprohd, unless it is recommended for some reason. If so, should I use compressor or?
thanks in advance,
td
