Optics can be quite confusing. When it comes to depth of field we normally hear things like you have to open up the lens by so many stops to match the DOF of super 35mm film or full frame.
But do I understand it right that for example a 50mm lens on a super 35 camera and on an AF100 would have the same exact DOF, and the whole opening up the lens to match DOF only applies if you are trying to match the FOV as well?
If that's right then a 50mm lens has the same DOF properties regardless of sensor size but it would naturally have different FOV with the different sensors. So 50mm on a super 35 camera and on an AF100 have the same DOF but different FOV. But if I try to match the FOV of a 50mm lens on a super 35 camera with the AF100 I would have to use a 35mm focal length lens, and then to match the DOF too I would have top open up the lens? Is this it or I have it totally wrong?
How many stops I have to open the lens to match super 35? I know to match academy is only 1/4 of a stop. But what about super 35?
