govindaBLU
Graeme_Nattress said:Full sensor full speed 60fps output is around 1GB/s, given that it's 12bit data. You can figure that number out yourself from the number of pixels, bit depth and fps. We're not ready to talk about compressed data yet.
Graeme
Greg Lowry said:4520 x 2540
RBG 444
12 Bit
60 fps progressive
Hmm, I calculate the data rate to be 3.1 GB/s (1.24 GB/s @ 24 fps). What am I missing?
baro said:I thought 1 Kbyte = 1024 bytes, 1 Mbyte = 1024 Kbyte, 1 Gbyte = 1024 Mbyte. Isn't that the way you count bytes?
Graeme_Nattress said:Well, RED RAID will do it, if you want to keep "in brand". Assuming you can hook up your PC to the camera (no, not over HD SDI for this, over some kind of fibre probably) then sure, you'll be able to record the datastream. You might need to write some code to spool it to a file, but no reason why it shouldn't work, and I don't think we're going to go out of our way to stop you, but I think RED RAID will be a better solution.
Graeme
