My sister teaches and dances at a local dance school that, like most dance schools, hold recitals a couple of times a year. The guy that had been recording it in the past had been doing so with a small prosumer DV cam and the footage was always overexposed and just generally not very good looking.
I've recently decided to offer my services to attempt to get a better outcome at a cheaper price and after getting some practice in at their winter show (which is usually not recorded) with an older consumer grade sony DV cam, I've been in the works to do their upcoming spring recital.
After some reading and price checking I figured this HPX300 would be more than enough to pull this off with a pretty nice looking finished product. A local audio/video shop happens to rent this camera out and that's going to be the most feasible option. The biggest problem is that I've never actually worked with a camera as advanced as this one (not even a prosumer camera). I've been reading over the instruction manual to try and prepare as best I can but there are many concepts that are difficult to grasp without my having played with the camera itself. Fortunately I'll have the camera for two days prior to the actual recital and I'll be at the concert hall while the dancers are doing rehearsal so I'll be able to play with the camera's settings and coordinate with the concert hall's technical director.
I am very concerned about a few things though; I want to shoot this in 1080/24pn or 30pn with AVCIntra 100. From what I've read in the instruction manual, the only means of recording AVC Intra is directly onto a P2 card...well the a/v shop only has one 16 gig card and the recital is about 5 hours long. I'm looking for some solutions and suggestions for this problem. One possible solution that I thought of still requires at least two 64 gig P2 cards and an external 1 TB HDD...but this solution also assumes that I can copy the contents of the non-active P2 card to an external HDD while it writes to the other. I don't believe the camera can do this from what I've read in the instruction manual so far. Another possible solution would require at least three 64 gig P2 cards, a laptop, and an external HDD. I could record to a P2 card and when that one is full and it starts recording to the other I pull out the non active P2 card, replace it with the third and copy the contents to the external HDD. Rinse and repeat...the problem with both of these solutions is two fold; I don't even know if they're the best solutions in the first place, and even if they are, I still need P2 cards which I don't know where to get.
My second concern is getting the right look; just looking at the camera tells me there are a lot of ways to play with the picture and looking through the instruction manual confirms this. It's a little overwhelming to me, and while I am trying to read as much as I can and learn as fast as I can, the recital is just a little over a month away. I'd like to be able to achieve an excellent looking picture over the two days of rehearsals and save the settings (I believe they're called scene files?) so I can pull them back up for the recital. The lighting conditions will be dark around the audience and consist of stage lights of different colors and intensities. If it helps at at all, here is the website for the performance hall that I'll be recording in: Jefferson Center Shaftman Performance Hall. I just need some suggestions/tips for setting up the camera visually. I think I'll be covered on sound; they always have mics set up on stage to pick up the tap dances and route them through the speaker system. He'll be sending the three channels of audio mixed into a single channel that'll head strait into one of the camera's audio inputs. The second and third audio channels will be for the audience sounds, and the announcer.
I'm sorry to have written so much, I'm just trying to prepare for this as thoroughly as possible. Thank you very much for taking the time to read over it all and for any and all help.
I've something of somewhat importance to add; a lot of people have been suggesting against this camera, or even against HD all together. If you're reading this and all you can think is "this guy shouldn't be messing with HD" please stop right there. I appreciate the concern that you have, but I've decided on HD and that decision might as well be written in stone. If you have any advice other than suggesting against HD, please by all means share.
Edit: The HPX300 is out of the question due to nobody around here having any P2 cards. I've decided (I think) on the AG-HMC150P after a few people suggested it here. Please keep this in mind as you reply, and thank you all again!
