Just posted this on Vimeo showing the D90 shooting the same scene in various modes - M,A,S and P.
http://vimeo.com/3651590
More info in my blog post here.
-a-
-a-
he's using a 50mm f/1.8 AF lens. I don't have any CPU lenses so I can't test the theorywhat did you find? i don't see any real difference and i wouldn't expect it either since these modes shouldn't have any effect in movie mode. with a manual lens you're always in "a" no matter what.
/matt
-a-
You can use most any photo or image tool. Use a black background, add a white layer on top. Change the transparency of the white layer in 10% increments between 50% white to 100% white and create a jpg at each step. Use iTunes to load the jpgs into your iPhone.
I set the 80% white jpg for my wallpaper (select the photo, click the icon in the lower left, choose "Use as wallpaper"). With my iPhone in sleep mode I can click any button to wake it up and it will display the 80% white image. It only covers the center half of the screen but that's usually enough to cover the lens.
The other thing to set is in Settings, Brightness. Turn off Auto-brightness and drag the slider to the right for full brightness.
Hope that helps,
-a-
