D800
  • Start date Start date
The resolution of the Nikon D800 looks higher than the 5D mark III in both of the last two videos (trees, hair). And, in the video at the temple, I can't see any moire. If there is moire, it must be on very fine lines, close together. The built-in codec looks like it's holding together well on detail.
I've decided to get the MKIII for now and see what happens with the development of a anti-aliasing filter for the D800. The other big concern I have with the D800 is that it might overheat faster than the MKIII (more megapixels = more heat?). The manual mentions that it has an auto shutdown when it overheats and won't switch back on until it cools down. I wouldn't risk just having one body on a shoot unless I was certain that overheating wasn't going to be a problem.
I agree but there's still quite a bit of aliasing in all the videos I've seen that I'm not seeing in the MKIII footage. Softness I can work with, aliasing I can't.
Please kindly elaborate as they are both 'twins'. Edge effects that are mask-able via DSP filters that are often simply programmed to do the opposite thing, 'alias' soft edges or soften aliased edges.
jcs over @ cinema5D has a good technical explanation for it.
There seems to be some aliasing on the D800, maybe due to the codec but I haven't seen much moire. The resolution on the D800 seems to be very impressive.
I'll have one in my hands fairly soon so I'll do some tests.
real world sample i found on vimeo , i think that might give us more info on the camera issues , unfortunately not recorded in hdmi output but internal https://vimeo.com/39073054
if you look at 1:32 the ups truck on the right has jaggy lines aliasing or something i wonder if this issues would be solved if recorded externally with hdmi output, but other than that IMO looks great , sharp and good DR
That particular video you linked, is in 720p. It may have been shot at 1080p, but the vimeo video is in 720p. I wouldn't make any conclusions about aliasing from that one.
This video http://vimeo.com/39097915 is very very encouraging compared to the last one. I am thinking if there was no workflow problem for the first one as the difference is staggering. The first one seamed to really lack a field in vertical plane and every straight line had some ugly aliasing. For one moment I was thinking if nikon had not done the line problem in the initial d90.
What seems good also is the DR and rolling shutter.
Just saw those.
Here's new footage from the D800 just uploaded too! One thing that is quite obvious is footage shot with the 85mm 1.4, has minimum rolling shutter/skew issues. It appears Nikon has their cmos readout way faster.
https://vimeo.com/38912704
Pappas
http://pappasarts.wordpress.com/
http://twitter.com/pappasarts
I measured the rolling shutter on my D800 at approximately 14ms for full frame, about the same as the RED Scarlet for its S35 size frame.
MKII is 25ms. I saw some figures on the MKIII and 1DX which was half of the MKIII a couple of days ago but I can't find them now :badputer:
