Is there a way to switch between shooting in standard def and hi def on the hvx?
1) I've heard that the hvx only shoots in hi def (when using a p2 card).
I only use p2 cards, so I was wondering if it only ever shoots in hi def. or if there is a way to switch between the two.
2) Is there a visible difference between shooting in Native mode than in P mode?
I have read that the only difference is that in native mode, the p2 card lasts longer and you don't get as much strobing. I don't know if that's true or not since I couldn't find any footage online showing the difference between native and P.
Does Native look any different than P after shooting or does it only have to do with how much more time you get on the p2 card?
Thanks in advance,
Nader
Thanks in advance,
Nader
