Very fast lens! But sharp enough to be professional usable? Any experiences?
Keep in mind you can't use it with the c-mount adaptors, because the rear barrel is too wide for the adaptor... Months ago I adapted this zoom to a M4/3 mount. Was a big nightmare to collimate it properly!! With crucial micro work in the rear parts of the lens with a lathe machine
This is really sharp in all focals, even at f1.0 f.1.2 at 48mm) and moving the zoom barrel is very smooth.
For me the question is that the ETC mode (the only way to use it in the GH2) is clearly less sharp than the full mode.
All the best.
sure, with the GH2 ETC it has great potential for many applications depending on your definition of pro though. I have the Pentax 12.5-75mm 1.8 and it's sharp as a tack. Great for music video's, experimental imagery, stylized documentary etc. It's not a cheap lens and yet to see anyone post imagery from that exact lens to date anywere.
Alfred: I paid about 80 british pounds in ebay.co.uk. The lens is generic for 1/2" (not 2/3"). I have many experience in adapting lens and cameras (I come from movie equipment...) and I can tell you that to adapt this lens to M4/3 isn't an easy job... It's necessary to separate and machining the rear lens parts (not only the c-mount). Collimate a zoom f1.0 (with a 8mm wide focal) is a precision work of 0.001 millimeter in all its parts...
Only the best.
You CAN NOT fit this Pentax 8-48mm zoom in any c-mount/M43 adapter. This lens is bigger than the 12.5-75mm. The rear c-mount barrel has 47mm in outside diameter, which is about 10mm wider than the top limit in these adapters.
I don't know what to make of c-mount extenders... I presume the fact that anything c-mount doesn't cover the entire m4/3 sensor, the c-mount extender may vignette anyway making it pointless to use it? Correct me if I'm wrong since I've never used one.How about using this (or any other wide c-mount) with a 1.5-2x c-mount extender?
