A can of paint costs less than storing RAW footage and would have solved your white wall problem.
Not sure why everyone still acts as if shooting CRL or giving it to clients is a big deal, it's really not. All of the big four handle it natively or with the Canon plug-in now, it's just a bit bigger than equivalent Prores.
I don't know what the difference would matter between giving the client RAW without a reference and anything else, if they can't trust the metadata.
Interesting Chris, but the data rate for Prores 422 is almost the same as for CRL, so again I wonder what the advantage is in conversion -- other than 1)may play back more smoothly or 2)handing the footage off to clients directly in a format they understand.
Just have your clients watch this video, it's clear that if you can load and edit off of an internal laptop, it's not going to be un-doable on the average editing station. If they have old and slow gear, use a proxy workflow. If they have anything even remotely modern, CRL is a breeze.
https://www.youtube.com/watch?v=I1P1hzAPbHM&t=10s
What about a color reference when processing the RAW footage ?
Will your client always be able to determine what the correct color balance is when editing your footage ? ( once you hand over your footage does this become the client's problem and not yours )
I know that I can generally make a pretty good guess as to what the final color-balance should be, but if somebody hands me their footage and I've never seen the environment they are shooting in, and I have no clue if the metadata stored in the footage shows the correct color-balance, all I can do is take my best guess at getting it right.
As a general rule, anything approaching 1Gb/s (4k Sony Raw, 4k CRL, 4k ProresHQ) and certainly anything exceeding it (2.8k Arriraw, 8k Redcode etc.) needs SSDs for offloading.
Unless you're shooting really low volumes of footage, there simply isn't enough time in the day to physically transfer that much data (512GB-ish per hour of footage) to spinning harddrives.
I'm slowly managing to convince producers I work with, to buy pairs of 2TB SSDs to use as their "transport" drives (which they then transfer to spinning drives when they get back to wherever they're going). But it's a long slog, and a hard fight to do so. Everyone have I brought around to the idea though, wishes they'd done it years ago (it just makes life SO much easier).
