Budgieboots
Hello,
I purchased a Canon 5D Mark IV last year to use as a stills camera.
However, more and more I find myself using it for 1080p video production because of it's excellent DPAF, even if it's a little unbalanced to use out in the field with minimal rigging.
At most, I've put it on a cheap shoulder mount or tripod and that's it. I've even preferred using it over something like a Sony FS5 because it just seems a lot easier to get a nice looking image with less post production time.
Recently, I've been commissioned to produce a short film on a under $10K budget, which is quite exciting for me because I normally do special events and corporate video.
I also have to deliver the final product in 4K.
So that said, I have some questions that I was hoping advice or answers could be provided on because while I have used proper video cameras before, I haven't done as much DSLR filmmaking.
#01:
I am aware of the large crop of the 4K with the 5DmkIV. The widest lens I have is a 24-105mm, so from what I gathered the best lenses to overcome it so that you can get wide angle shots in 4K are:
Sigma ART 18-35mm f/1.8 DC HSM Lens for Canon (it's supposed to work out from what I read online? even though it's not full-frame)
Canon EF 16-35mm f/2.8L III USM
Sigma ART 12-24mm f/4.0 DG HSM Lens for Canon
Canon EF 11-24mm f4L USM
It's my understanding all those lenses also work just fine with the DPAF. I had heard of the Tokina 11-16 F2.8 being recommended, but I wasn't sure if that one could do auto focusing.
I have minimal crew on the camera side, so did not want to have to rely on manual only lenses and having a camera assistant to pull focus for every scene. What I've done so far with DPAF as a one-man band, I've been quite happy with.
#02:
I would like to invest in an external, on-camera field monitor to overcome the lack of zebras and histograms on the 5D Mark IV.
Is there a definitive amazing monitor that does this?
I've heard good things about the Small HD brand.
Also, are there any external field monitors with touch screen you can "tap" to also do the DPAF?
Does that technology exist?
I suppose the alternative would be using the "Canon Camera Connect" app on my iPhone.
#03:
I will have to do some scenes outdoors, so would require ND filters. I would just be using my Canon EF lenses to shoot this -- I presume the simplest solution is just to place a screw-on filter on the lens itself instead of a whole matte box setup?
I know from my experience with the FS100s that variable ND filters really make things unsharp, so it's better to use dedicated ND's.
#04:
Any recommendations on EVF's?
If you use one of those Zacuto EVF's that clip onto the camera body, how do you use the DPAF? Or is it back to using your iPhone to do it?
#05:
Can you power a 5D Mark IV off a v-mount battery? What would be fantastic is if there was a rig that both powered and fit the camera, monitor and external audio recorder.
Does such a thing exist without having to pick and choose bits and pieces from different vendors? A nice, all-in-one, if you want to make a frankenstein rig, this is what you need?
Thanks!
#01:
#02:
#03:
#04:
#05:
Thanks!
