Convergent Design - New Firmware - Avid DNxHD and Varicam LT 240 fps Raw Support
Dear Parrot,
1. No, we support only 720p/1080p on Dual Monitor / Recording (No 2K support).
2. What are the issues with Varicam pure? Are you trying to record Raw from Varicam Pure via an Odyssey7Q or Odyssey7Q+?
3. We do not currently support ARRI 6G SDI output, but HD-SDI 3G Dual link should work fine for ARRI 4K UHD up to 30p, but we have not tested this in our lab yet.
I hope this helps.
Respectfully,
Dan Keaton
Convergent Design
The VariCam 35 and VariCam PURE output 4K as Quad-Link 3G-SDI. I believe the Odyssey doesn't accept this at frame rates other than 50p/60p.
Is there any estimate for an update to work with HLG for the Sony RAW? Really interested to do some HDR content using the Odyssey. Also interested if full 120fps will work if the added license for the FS5 is purchased.
Dear Derek,
We want to support HLG, we are not ready to do so, and I do not have a timeframe yet.
If you have an FS5 or FS700 and our Raw Bundle, then we support 2K in 100, 120 fps, 200 and 240 fps continuously.
There is also a cached mode for 4K Apple ProRes at 100 fps and 120 fps. (This is a limited time recording due to the way the camera handles these modes internally.)
Respectfully,
Dan Keaton
Convergent Design
Thanks Dan,
I totally blanked that 120 at 2K is already there and I guess this new update doesn't add 4K 120 on the output. Look forward to the HLG update whenever it may be. Currently makes more sense to shoot 4K 10bit Slog2 on the 7Q and grade for HDR than shoot internal 8 bit HLG.
Just got the new newsletter about Firmware v2017.07 for CD's Odyssey/Apollo - but it looks exactly like the previous 2017.06 update?1? - Everything in the text, new features, etc looks the same - FREE Titan HD, DNxHD 60p and 2K/240 Raw from the Vari LT? Was this an error in the mail-out or....
Did anyone receive the same email?
Dear K0bayashi,
That is correct. The email that went out was to alert people of our free Titan HD Extract and Avid DNxHD Support.
Here is some information on our latest firmware release 2017.07.1713, and it combines into one the features that we added in June with the features and fixes that we just released.
Dear Friends,
We now have a new firmware version for the Odyssey and Apollo, version 2017.07.1713.
This is an incremental release, adding a few features and some important fixes.
This is an important release, as some of the fixes are critical.
For clarity, in the release notes below, I have included features that we incorporated in our 2017.06 releases.
It is very important for Panasonic Varicam LT users to install this version since if one is using this camera, and using a non-smart lens, then the files will be corrupted.
It is also important for Avid DNxHD users to update to this version.
We found an error in our Apollo Mode where we would not properly handle lost of camera signals.
Please note that we made our Titan HD Extract Option free recently,
and we added Avid DNxHD support.
Release Notes 2017.07.1713
Firmware Update for Apollo / Odyssey 7Q+ / Odyssey7Q / Odyssey7
NEW FEATURES: APOLLO & APOLLO OPTION (ODYSSEY7Q+/7Q)
Quad-HD: Avid DNxHD .MOV Support
● Simultaneously record up to four streams of Avid DNxHD 220 or 145Mb.
● 1080p 23.98, 24, 25, 29.97, 30, 50, 59.94, 60
● 1080i 50, 59.94;
● 720p 50, 59.94, 60
● Note: Activation Key required (free) to enable Quad-HD DNxHD .MOV Support.
Quad-HD Quad-Split: Timecode Option
● Option to “deselect” or select a Timecode window which is baked into the Quad-Split recorded image in Quad-HD Apple ProRes, or Avid DNxHD Recordings.
NEW FEATURES: ODYSSEY RAW BUNDLE (ODYSSEY7Q+/7Q)
Panasonic Varicam LT 2k/ HD 240p Support
● Record RAW in CinemaDNG from the Panasonic Varicam LT
● Variframe Supported from 2->240 fps
● HD LT RAW -> HD Cinema DNG 23.98, 25, 29.97, 50, 59.94, 100, 120, 200, 240
● 2K LT RAW -> 2K Cinema DNG 23.98, 25, 29.97, 50, 59.94, 100, 120, 200, 240
NEW FEATURES: ODYSSEY ( ODYSSEY7Q+/7Q/)
● Single Channel Recording to Avid DNxHD 4:2:2 at 220 or 145 Mb.
● 1080i 50, 59.94; 720p 50, 59.94, 60
● 720p 50, 59.94
Note: Activation Key required (free) to enable HD DNxHD .Mov Support.
NEW FEATURES: ALL MODELS (APOLLO, ODYSSEY7Q+/7Q/7)
8-Channel Audio / 2-Channel Audio Selection
● Selection is now available for Embedded Audio to be either 8-Channel or 2-Channel in various record modes including:
○ HD/2K Apple ProRes
○ HD Avid DNxHD
○ 4K/UHD Apple ProRes
○ Quad HD Apple ProRes
○ Quad HD Avid DNxHD
Note: 8-channel audio not available in RAW, RAW->Apple ProRes, DPX, or Apple ProRes 4444 modes
FIXES & IMPROVEMENTS
Apollo
● FIXED Input loss Recovery with Avid DNxHD Files
● FIXED 2:3 Pulldown Support
● FIXED Audio issue found with QT files and Telestream
● IMPROVED Source Naming added to XML file
Odyssey RAW Bundle
● FIXED Varicam LT MetaData Issue with Non-Smart Lenses
● FIXED Rare Canon RAW -> Apple ProRes frame issue
● FIXED Rare Canon RAW -> Random Touches
● FIXED Rare ARRIRAW -> Random Touches
● FIXED Sony 4k 100/120 fps burst -> HD/2K Apple ProRes half length recording
● IMPROVED Playback Scrubbing artifacts of RAW recordings
● IMPROVED Record Button Allowed with FS5/FS700 4K 100/120 burst,
All Modes, allowing users to record 4k 50/60p via record button and
4k 100/120 with camera trigger
All Devices
● FIXED Apple ProRes Playback Scrubbing artifact in lower right corner.
● FIXED Issues associated with Computer Generated Images
● FIXED occasional black playback in Apple ProRes
● FIXED corruption issue when new generation Samsung 850 EVO drive
● IMPROVED Voltage Display Accuracy.
● IMPROVED Dual 6G SDI Support.
● IMPROVED Playback Quality with all Apple ProRes recordings
● IMPROVED Detection of 4K 50/60p signals.
● RESTORE DEFAULTS Is now automatically performed on power-up immediately after a firmware update (a dialog alerts user when this happens).
Please note settings before updating, and adjust settings as needed after updating.
SOFTWARE
CD Apple ProRes and Avid DNxHD Transfer Tool 3.0 (Updated)
● Support Added for Avid DNxHD Files, Note DNxHD recordings will not work with previous transfer tool.
● Windows and Mac versions available
Avid DNxHD .MOV File Support with QuickTime Player 7.
“Avid Codec LE” must be installed on systems you wish to play Avid DNxHD files in Quicktime Player (Mac or PC) . Avid QuickTime Codecs LE
Avid DNxHD .MOV NLE Support
DNxHR & DNxHD | Avid
Avid DNxHD .MOV AMA Support
ARRI DNxHD AMA Plug-in
Respectfully,
Dan Keaton
Convergent Design
I got my activation keys for the DNxHD and Titan upgrades, and I updated the July firmware as well. I can't figure out how to select DNxHD recording. My recording choices are only ProRes types. (I have an Apollo)
Dear Dave,
If you are using our 2017-07-1713 firmware, please select "Apollo Quad-HD DNXHD", instead of "Apollo Quad-HD:proRes under Monitor -->Record in our Setup Menu.
I hope this helps.
Respectfully,
Dan Keaton
Convergent Design
Well, I still can't figure it out!
Under "video codec" the only options are the 4 ProRes types. Is the menu a little different with the Apollo vs. Odyssey?
Sorry for late reply. Been off this forum for a while. Thanks to Dan & Mitch for answering my questions. Explanation seem plausible as I've only tried to connect at 23.976 (I think). I would think that compatibility with Standardized Baseband Video Signals in 4K & UHD should have benefits for more people than just users of Varicam Pure & 35, so hopefully something it's worth fixing for Convergent Design (if it's on their end...???)?
I will answer my own question here since it was not explained to me... with an Apollo you click on Menu / Setup / Master Camera / and then the bottom option is DNxHD. That's it.
There hasn’t been any new developments in 7Q+ firmware since June. Can we expect anything coming up or is it EOL?
Very interested in this as well! Hope CD can share some info on this.
Dan Keaton posted on another website.
"We are researching Apple ProRes Raw at this time.
We do not have any news to report right now.
Respectfully,"
I wonder will they have news at NAB?
It would be wonderful if it's to be supported. I'd hate to have to change out the Odyssey for an Atomos, as so much has been invested in it; and I've really gotten used to it's tools.
Even better would be an upgrade path to a newer monitor which could use existing SSDs and mounts. Perhaps a brighter one of over 1000 nits with the same features. Hint hint :laugh:
It would be great to keep the old FS700 going for another few years.
Prores RAW would be so awesome on the Odyssey7Q! I bet they will be able to add it! I thought there was no way they would get Sony to allow them to use the RAW feed on the Odyssey 7Q from the FS700, but they made it happen! Convergent Design you are the best!
Yes I'm still rocking the FS700/Odyssey 7Q+ combo. Incredible how a camera 5 years old can still hold its own with the Odyssey. It would be amazing if CD could add ProRes raw to the 7Q+!!
