Controlling Audio through mic input...
NigelDark
Hiya,
Just had a question regarding the mic levels and how to change it? I've got just one input via xlr to mini adapter...Can't find the volume control?
ND
Hiya,
ND
When you are using the internal microphone or a microphone attached via the 3.5mm connector --> use the Q.MENU to change the mic level from FIX to MNL. When the mic is set to MNL then you can adjust the level using the Function Navi menu on the LCD. The settings are pretty coarse (-3 dB increments going negative and +2 dB increments positive).
