MattDavis
Have searched for these answers, apologies if I've missed them...
I've been spending quality time with a friend's HVX200 (much loved, much used). I've been enjoying its look, the DVCPro format, and all the heartwarming stuff that is part of the HVX. However, there are some oddities that aren't exactly fatal flaws, but can be classed as things that make me go 'hmmm'.
I note a slight darkening as I move from SD to 720 to 1080 on the HVX, not much, but it seems there's a slightly different setup for gamma and the like for the different resolutions. Is this a feature or a bug?
Similarly on the feature/bug list, I note that the lens barrel needs quite a bit of twiddling to go from one end of the focus to the other, thus making quick focus pulls quite a challenge on your own. The Z1 is coarse in comparison, but a good heafty tweak can get you from bokeh to pop. Is there a knack for the HVX? (I guess it's called 'your focus puller')
Shooting time-lapse to P2 with 5700mW (sic) batteries, I'm getting about two hours before it gets hungry. Whilst the solution may be to buy more batteries, I'm concerned that I'd hope for double that operation on a battery. Maybe I've been spoiled by the Z1, but I can shoot 3 hours plus on a single battery, and a day's shoot with two (and two pocketfuls of tapes). Maybe it's tired batteries. Maybe HD onto solid state media is more power hungry than I thought (I note the EX-1's new battery ratings, for example).
Does anyone use de-noising in post on a regular basis with HVX footage? I've turned the sharpness down in-camera and add just a teeny bit in post, and some of the boiling noise can be wiped away with de-noising, but it seems to be quite a few steps in that elusive chase for the perfect shot.
OTOH, I notice HVX footage can take way more grading than Z1 (yes, of course this is obvious), but even with DV, the HVX footage - when underexposed - can be pulled up with far less savagery than the Z1. Do shooters who edit their own material tend to go for in-camera looks over shooting flat and adding the look in post?
Lots of questions - but lots to learn!
Thanks, M.
Thanks, M.
