keylight
Per,
Please indulge me one more time. What you are saying is that I do a regular timelapse, but each single shot would include a bracketed sequence?
Start with a single still photo:
If you shoot a bracket of 5 photos, you can later select the one photo that has the best exposure and start developing that photo in lightroom/photoshop.
OR
You can merge the 5 photos together to get a single HDR photo.
Okay, since a timelapse sequence is nothing more than playing back a series of still photos (let's call them frames that you play back at 30 fps), you can do the same thing with the timelapse.
Only when shooting for timelapse, if you're doing a sunset shot, set your EV-2 so that it is correctly exposed (your EV+2 will be grossly over-exposed).
Here's an example (note that I shot this sequence to do an HDR, so the EV-2 is too dark to be my "correctly exposed" image but it's still useful for illustrating purposes):
So you shoot each frame bracketed and then separate the various exposures to create 5 identical sequences. So all EV -2 photos go into 1 folder, EV-1 in a second folder, EV 0 in a third folder, EV+1 in a forth folder, and of course EV+2 in a fifth folder.
So after putting them into 5 folders (using the method attributed to milapse but done by a lot of people for years before):
Then you go into each folder and batch rename all the images in the EV-2 folder so they are sequential (I use this super powerful renaming tool: Advanced Renamer). Import the EV-2 sequence into your NLE and you've got a timelapse that is under exposed by EV-2. Do the same thing for each of the other 4 folders and you'll have 5 separate and identical sequences, the only difference being the exposure. You can then cross dissolve between these 5 sequences as you wish.
So your EV-2 sequence would be exposed correctly at the start of the sequence, and by the end, your EV+2 will be exposed correctly.
Now, you can extend this whole process out even further if you have a long enough interval between frames. How? Add a full stop ND to the front of your lens and start your EV-2 correctly exposed. By the time your EV 0 is the correctly exposed image in your bracket, carefully pull the ND filter and your EV-1 will become your correctly exposed image.
