Compressor 3 incorrect detection of cadence for HV20 24p clips pulldown removal
ikester
Hi all,
I've been processing some 24p clips from the HV20 using the "Apple" method with Compressor 3.0.2 and I'm getting inconsistent results:
Compressor doesn't seem to always find the right cadence and I can still see interlacing artifacts in the resulting 23.98 ProRes 422 Quicktime file. This only happens with some clips. Others are processed correctly. Surprisingly, the same clip is processed correctly by JES Deinterlacer.
I'm also seeing inconsistent color/gamma settings as compared to the original and JES processed clips. To recreate, remove the pulldown for a test clip with Compressor and output to a ProRes file. Then remove the pulldown for the same clip with JES and output to a PhotoJPEG file. Now create a ProRes 422 23.98 sequence in FCP and place both processed clips on the timeline. The gamma varies slightly with the PhotoJPEG being closer to the original 60i clip, in my experience.
In addition, there's the annoying side effect that the new 24p ProRes clip doesn't respect the anamorphic flags when viewed with the Quicktime Player. I've tried all possible combinations in the Geometry section of the Compressor settings and I cannot get it to generate a clip with the correct pixel aspect ratio.
The bottom line is that now I can't trust the "endorsed" workflow to do the right thing on a large batch of clips.
Has anyone else noticed this? Am I missing something obvious? Any tips or working compressor settings would be greatly appreciated.
Ike
